Re: SM Stage 12 serial number break
Posted by D Slater on September 29, 2013 at 03:58:12 from (184.14.160.234):
In Reply to: SM Stage 12 serial number break posted by Centex Farmall on September 28, 2013 at 20:14:51:
Louisville stage 2 L-504802 and higher. Farmall stage 2, F-28175 and higher. Below that stage 1.
Diesel, high crop and other models had a little higher start to stage 2, but don't think they made any of those in stage 1 after the serial numbers above so those numbers work for all.
