Re: H overheat
Posted by Janicholson on September 29, 2013 at 11:36:31 from (199.17.6.25):
In Reply to: H overheat posted by bassndeere on September 29, 2013 at 10:40:42:
First be sure the gauge is not malfunctioning. Is there boiling and overflow? If so one possibility is a hose (either upper or lower) that has an internal flap acting like a heart valve and closing off the flow. Even with a stuck Thermostat they bypass enough to cool unless worked on 50% power in most cases. Look for combustion gasses in the coolant as it warms up from cold. (Kit from auto store) Then watch the coolant flow (from cold, to the 10 minute mark as it should show nice flow with no scalding your face. A digital remote (laser aimed) thermometer is way handy to see where the heat is. Timing will also make a radcal overheat if retarded. Let us know what happens. Jim
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
