Posted by jimb2 on September 29, 2013 at 14:24:56 from (99.241.76.141):
In Reply to: Re: IH 684 Brakes posted by StuartR on September 29, 2013 at 14:18:28:
Yes, there should be a plastic reservoir up above the brake master cylinder to keep a supply of hydraulic oil for the brakes when engine is off. So if the brakes are applied with engine off or there is a small leak the master cylinder will not be full of air. Similar to the older cars where the master cylinder has the brake fluid reservoir attached on top.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
