Re: Troubles adding hydraulics to an M
Posted by pete 23 on September 29, 2013 at 18:21:13 from (74.33.77.105):
In Reply to: Troubles adding hydraulics to an M posted by hiperdart on September 29, 2013 at 15:38:47:
If you did the full M&W conversion, running the pressure in through a special fitting that takes the place of the original pump drive coupler, removed the gears, then welding the original suction tube shut inside, it should work. Then it uses the original relief valve and you lock the original lever into the lift position to use the 4 way valve you have added.
