Re: H overheat
Posted by David G on September 29, 2013 at 18:32:50 from (205.215.206.18):
In Reply to: H overheat posted by bassndeere on September 29, 2013 at 10:40:42:
I would agree with Jim on the thermostat not having much impact on an H, the bypass is quite large. This should also prevent air pockets in the block.
I would expect bad gauge, head gasket leak or slow timing.
