Re: farmall h water pump
Posted by SadFarmall on September 30, 2013 at 03:38:22 from (121.79.0.151):
In Reply to: farmall h water pump posted by Harrison58 on September 29, 2013 at 21:59:08:
Rebuild kits surely are available from various sources. I rebuilt mine and found it a fairly simple operation, once I learnt (via this forum) where to find the small locating pin in the pulley. Zach Hoyt helped me out with a second pump for parts because part of mine was cracked. Rebuilding a Farmall H water pump is a satisfying job because it is (usually) not too difficult and, providing you are careful about fitting the bearings and seals correctly it will work without leaking. Also much cheaper than buying a new pump. Go for it!
SadFarmall
