Re: wont run after new carb install
Posted by mkirsch on September 30, 2013 at 05:12:52 from (64.80.110.74):
In Reply to: wont run after new carb install posted by pisgah ihman on September 22, 2013 at 14:42:34:
If you went to the parts store and said, "I need a coil for a Farmall M" they will sell you a 6 Volt coil.
If your Farmall M has been converted to 12 Volts, and you put that 6 Volt coil on without a ballast resistor, it will get HOT within about 5 minutes, and your tractor will start to sputter and miss.
You need to get a 12 Volt coil that is labeled "no ballast resistor required" or you need to install a ballast resistor between the ignition switch and the coil.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
