Re: Troubles adding hydraulics to an M
Posted by kevinj54 on September 30, 2013 at 06:28:19 from (162.17.149.81):
In Reply to: Troubles adding hydraulics to an M posted by D Slater on September 30, 2013 at 06:22:40:
That could be, but then I believe the old operating lever is removed and the system uses the internal relief.
He has not said if the belly unit was gutted out. I assumed it was like mine with lift all and M&W live to the rear.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
