Re: Troubles adding hydraulics to an M
Posted by D Slater on September 30, 2013 at 12:44:13 from (184.14.160.234):
In Reply to: Re: Troubles adding hydraulics to an M posted by mkirsch on September 30, 2013 at 11:41:12:
No, if the piston in the liftall valving is in the neutral position the oil will just circulate like it does when it driven by the counter shaft.
Control lever and inside linkage is hooked to the piston. When the rod is pulled back the buypass port to circulate is closed off. When a remote control valve is installed and the rod locked back the oil circulates through the remote control valve and back to the reservoir unless its operated. Thinking he didn't get the linkage hooked inside the unit and the piston is setting in neutral and no pressure to the port going to the remote control valve.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
