OT, not a IH , but confirm my suspicions
Posted by clint s on September 30, 2013 at 16:27:09 from (108.183.224.168):
Look down at the temp gauge on our Farm Trac and it was pegged to the red. Problem was it had only been running for 60 seconds at best. Trying to confirm it is the sending unit. Gauge will sometimes be pegged, sometimes read normal and sometime fluctuate up and down. If I remove the wire it drops all the way back, if I ground the wire it pegs. With the wire removed during use it stays all the way down. So gauge seems to be working properly (pegged grounded and stays all the way back removed) and since it stays all the way down with the wire removed I guess the wire is good. That leaves the sending unit correct???
Thanks Clint
