Re: H overheat
Posted by bassndeere on September 30, 2013 at 18:18:47 from (74.196.186.81):
In Reply to: H overheat posted by bassndeere on September 29, 2013 at 10:40:42:
Tested thermostat and gauge tonight. 160 degree thermostat, opened at 165/170. Gauge needle on U at 180 and on the N at 210. When she overheats it goes past the T on hot, instantly. Water blows out past hose clamps. Other than that she runs smooth and pulls good.
