Re: roosa master timing problems
Posted by jdemaris on October 01, 2013 at 05:02:43 from (70.192.12.151):
In Reply to: Re: roosa master timing problems posted by arkie on September 30, 2013 at 18:53:18:
From the Allis Chalmers HD4 manual:
Procedure for air-timing when pump timing marks
are "questionable" or missing.
A. Connect air pressure (30 to 100 PSI) to fuel
discharge port #1. You might have to fabricate
something to do this. I use the banjo-end from an
old injector line hooked to an air-chuck.
B. Viewing the timing line on the pump-cam
through the timing window, rotate the pump in
normal direction of rotation (with pressurized air
line hooked up).
C. When resistance is felt, the cam rollers
inside the pump are just contacting the cam
(getting ready to inject).
D. At this point, the two timing lines in the
pump window should be in line. If not, one is
incorrect.
