Re: Farmall H input shaft bearing
Posted by Zachary Hoyt on October 01, 2013 at 07:22:41 from (184.12.72.119):
In Reply to: Farmall H input shaft bearing posted by PretendFarmer on October 01, 2013 at 06:46:23:
To replace it remove the belly pump and take out the four tapered
bolts in the plate in the input shaft. The input shaft will come out
of the clutch and then you can unbolt the input shaft bearing carrier
from the front of the transmission and remove it. I have good used
parts if you need them. I am sure the bearing can also be had new.
Zach
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
