Re: Tisco sleeve and piston set woes
Posted by farmallman1949 on October 01, 2013 at 09:31:10 from (70.195.64.21):
In Reply to: Tisco sleeve and piston set woes posted by zooeyhall on September 30, 2013 at 17:23:08:
I have put in multiple Tisco engine kits and I always freeze the sleeves and pins and I use diesel fuel poured into the water jacket (about 1.5 to 2 quarts) and end then light the fuel after the sleeves have been in the freezer for about 4 hours. I then use a propane torch to heat the pistons and the pin end of the rod after I get the sleeves in the block and then proceed to put the piston and rods together. This trick has worked every time for me. And on another note Tisco has 4 different engine kits that fit a M. Some times if you go by the serial number plate for the tractor you may get the wrong kit always go by the serial number that is stamped on the engine and even then you can still get the wrong one.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
