You will have to start the repair on input end. Have to be very careful removing the valve end housing as the spool slides out of housing and stays with shaft. Then you take roll pin out holding input shaft to motor end, observing the slot and hole direction in the roll pin. Probably tear up shims getting it apart and need new ones along with the O-rings and seal and gasket. I always replace worn roll pins and spring in spool end unit. Torque is 70 ft lbs if memory serves me correct.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
