Re: 300 is home!
Posted by Lmack on October 01, 2013 at 12:32:57 from (24.131.50.165):
In Reply to: Re: 300 is home! posted by bigboreG on September 30, 2013 at 20:24:03:
I would suggest you run it for a while before you jump on a total redo of the carburetor. Do drain the carburetor bowl, the tank bowl and blow out the fuel line and try to put it under load for about a days work like pulling a 6-foot stalk cutter or bush hog. If it has been setting for a while you might have to drain the two bowls and blow out the fuel line several times. A thorough carburetor cleaning will not eliminate this unless you drain and flush the fuel tank first.
