Got it - ended up at Tractor Supply. Bought their 12" receiver blank, 2 3/4 inch bolts and hardware.
Friend across the road has an industrial size drill press that we knocked two 3/4 inch holes in the tube. Tube fit perfectly over the draw bar and gave enough room for the hitch to slide in.
Thanks for the suggestions and help.
Good part is the ball will be right at the rear of the tires so turning radius is going to be pretty short...
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
