Posted by Bob M on October 01, 2013 at 15:03:24 from (173.225.52.219):
In Reply to: what to do? posted by jamie majors on October 01, 2013 at 13:24:20:
My Super H sits unstarted for 6 - 7 months every winter/spring. Here's what I do:
Shut off the fuel at the sediment bulb and run the engine until it quits. Then remove, clean and replace the glass bowl.
Disconnect the battery ground cable, or remove the battery.
Either fill the fuel tank full, or drain it completely. Don't leave it with a couple inches of gas in the bottom - if the gas contains ethanol it'll attract water, go stale and may cause rust inside the tank.
Finally if the tractor is stored outside place a large can or bucket over the exhaust and tie it down to keep rain out. I also like to cover the seat.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
