Re: F20 coolant leak
Posted by 36F30 on October 01, 2013 at 21:18:02 from (174.30.91.121):
In Reply to: F20 coolant leak posted by doehmke on October 01, 2013 at 19:31:42:
The holes for the manifold studs actually go clear through the head and need to be sealed with sealant during assembly. You will have to drain the coolant, remove the carb and manifold and then the stud. I use aviation form a gasket but any thread sealant should do. Coat the stud and put it back in. Might as well do them all while your at it. let it set up overnight and reinstall everything. The bolts holding the oil pan on also penetrate the block and will leak oil if not sealed and will mess up a nice paint job. Bottom line is the F series likes to mark their territory.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
