Re: F20 coolant leak
Posted by doehmke on October 02, 2013 at 04:03:09 from (74.5.83.25):
In Reply to: F20 coolant leak posted by doehmke on October 01, 2013 at 19:31:42:
That's good to know, Tom. Didn't see any oil leaks yet on the pan, but sppose it wouln't be long if ghat's the case with the bolt holes. Only had it running 3 times so far about 10 minutes each on a temporary gas tatank. Though that was enough time for one of the inpection covers to already leaking oil, despite new gaskets. Suppose the cover may be bent and not sealing properly.
