The convertor/regulator uses coolant to heat the liquid propane to convert it to vapor.
Check the electrical system first to be sure you are getting spark at the plugs.
Start by having both tank valves closed. Crank the engine to make sure it is not flooded. If it was flooded it will fire a time or two as it clears the excess fuel from the system. Next open the vapor valve. If it is real quiet you should hear fuel go through the valve just as you start to open it. The flow should stop as soon as the pressure equalizes. There should be no fuel leaking through the regulator. The regulator is opened by vacuum as the engine cranks. (Either 1 1/2" or 1/2" water column depending on what regulator is installed.) If the engine still doesn't fire and you have made sure it is not flooded you can try putting just a bit of gasoline in the carburetor and see if it will fire.
Once the engine is running and has started to warm up you can open the liquid valve.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
