Posted by pete 23 on October 02, 2013 at 20:14:49 from (74.33.76.49):
In Reply to: 1440 fuel question posted by 1370rod on October 02, 2013 at 18:12:00:
Does the hand primer leak when you pump it and pumping it should be all that is needed to refill the head of the pump. If it leaks externally it may allow leak down. Also, there should be an o-ring on the outside of that hand pump that seals when you tighten the bail. Could be the check valve in the charge pump.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
