Re: Farmall M Crankshaft/Flywheel question
Posted by Janicholson on October 03, 2013 at 10:23:04 from (199.17.6.37):
In Reply to: Farmall M Crankshaft/Flywheel question posted by CrvnJ on October 03, 2013 at 09:25:14:
If the ring gear is loose on the flywheel it will act like that. If you put it in High gear (5th) and rock the tractor back and forth hard, the engine should move (fan turn) with the motion. if it does, it is the ring gear. If not it is the crank to Flywheel, or broken crank.
With the starter off, doing the above check will allow you to see if it is the Flywheel or loose ring gear. If ring gear, the tractor needs to be split to replace it. Not hard to do once split. Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
