Re: want to change 1st gear to make tractor go slow
Posted by mkirsch on October 03, 2013 at 13:26:35 from (64.80.110.74):
In Reply to: want to change 1st gear to make tractor go slow posted by Farmall Bob on October 02, 2013 at 04:56:00:
The International B275?
The B275 has a "constant running PTO." In other words, live PTO. A Farmall C does not have live PTO.
If a Farmall C had live PTO, you could put some sort of reduction gear in between the engine and transmission to get an effective creeper gear for rototilling.
Live PTO has a separate shaft connected directly from the engine to the PTO, bypassing the transmission, so it will run at the same speed no matter what the transmission input shaft speed is.
On a Farmall C, the PTO is driven off the transmission input shaft. If you reduce the RPMs on the input shaft, you reduce the RPMs of the PTO, rendering it useless.
