Re: MTA Rotor
Posted by scott mcintosh on October 03, 2013 at 19:19:57 from (216.180.204.158):
In Reply to: MTA Rotor posted by metalmender on October 03, 2013 at 15:34:41:
I have had a bad condenser burn up points pretty fast but never a rotor.Try new points and condenser.Also is this still 6 volt or 12 volt conversion.Coil output sounds ecessive.Are these rotors OEM or aftermarket.Scott
