Re: IH 595 Clutch
Posted by Deere 620 on October 04, 2013 at 10:04:58 from (71.50.21.66):
In Reply to: IH 595 Clutch posted by Ronny Perryman on October 04, 2013 at 08:09:36:
If the flywheel is a two step style, it"s quite possible that someone has refaced the clutch surface of the flywheel and not the lip where the pressure plate bolts to. this will reduce the force of the pressure plate
