H no oil pressure update-thank you all
Posted by Zachary Hoyt on October 04, 2013 at 11:07:54 from (184.12.72.119):
I ran out of daylight last night to work on the H since I was catching up on some things that had to be done before the rain came. Today I pulled the pan, the pickup was clean so I removed it and installed it on a pump from a parts tractor that had a squashed pickup. I put that pump on the tractor and put the pan back on and the oil back in and started it up and had a nice steady 40 psi, not great but not at all bad. I took the cover off the pump and could see where the gears had worn into the cover, I will try to fix it sometime to be another spare. I do not know the internal condition of the pump I put on but it seems to be better, at least somewhat. Thank you all very much, I am very grateful for all of the advice.
Zach
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
