Re: 1951 M Flywheel bolts sheared!
Posted by glennster on October 04, 2013 at 13:58:00 from (76.222.60.10):
In Reply to: Re: 1951 M Flywheel bolts sheared! posted by CrvnJ on October 04, 2013 at 13:37:07:
i looked back at your other post and saw you have a chipped piston on cly number 2. i would pull that piston and check the wristpin, and also the rod bearing. having the tractor split at this point, you may want to think about doing a major on the engine. yt has the rebuild kits , and if you need a clutch, call mike at steel wheel ranch, he can set you up with the whole works very reasonable.
