Re: Correct PTO assembly on 53 Sh II ?
Posted by Owen Aaland on October 05, 2013 at 13:41:07 from (216.47.34.57):
In Reply to: Correct PTO assembly on 53 Sh II ? posted by RustyFarmall on October 05, 2013 at 07:15:51:
Technically, there were three different PTO assemblies used on the H model. There was also another style used for a short period that looked very similar to the first style on the outside but the engagement inside was changed from the dog clutch type to the later spline style clutch.
The serial number break down is as follows:
Type 1 501 to 45613
Type 2 45614 to 117999
Type 3 118000 and up.
Tractors originally equipped with the second style could be upgraded to the later style by just changing the PTO assembly. Tractors originally equipped with the original style generally needed the later style transmission counter shaft to use the later style PTO assemblies.
There was an adapter that could be used to convert the dog clutch style counter shaft to the later style but I don't know how well they would work once the shaft was worn out. The ones I converted would not stay engaged because of too wear on the dog clutch. Since the counter shaft had to come out to be repaired it was easy to just upgrade to the later style shaft.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
