Re: farmall 806
Posted by rankrank1 on October 05, 2013 at 17:46:29 from (198.228.228.176):
In Reply to: farmall 806 posted by avant tractor on October 05, 2013 at 16:41:48:
Lots! Roughly 6 gallons per hour under light loads in most cases up to over 9.6 gph under full load. Course even the tiny loads are tested at Wide Open Throttle.
The tractor will literally burn 3 gph running WOT and accomplishing zero work so a fuel miser it will not be. Propane is cheaper right now though, and it burns clean, and no carburetor to crud up from old stale gasoline so there are still some benefits.
Here is link to full Nebraska test report (may need to copy and paste it to your browser).
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=2294&context=tractormuseumlit&sei-redir=1&referer=http%3A%2F%2Fwww.bing.com%2Fsearch%3Fq%3Dfarmall%2B806%2BLPG%26form%3DIE10TR%26src%3DIE10TR%26pc%3DMALNJS#search=%22farmall%20806%20LPG%22
