Re: HYDRAULICS
Posted by gene b on December 04, 2000 at 05:22:33 from (63.15.137.101):
In Reply to: HYDRAULICS posted by MENACE on December 03, 2000 at 19:04:03:
is your block made for the pump below the mag there should be a hole with two tapped places for the pump to fasten to then you need the lines to the rockshaft assy below the gas tank these components should be there if you have a SA some people use the rear shaft that lifts the plow for the lift arms the lower units cad be fastened on the holes in the drawbar area glad to help
Post A Followup
: Re: Re: HYDRAULICS
