Rebuilding 544u shift linkage?
Posted by kev@IA on December 04, 2000 at 06:18:40 from (207.177.4.152):
Dad thinks this needs to be done because the center link dropped on him so he was stuck in 2nd gear. I am assuming these can be built up with brass rod? I am pretty good at ox/acteline.
Of course if they are steel plate a wire welder is much faster, I have built up severl things already with mine. This style shifter is a H pattern mounted on the right side of the hood used on 544 and 656 maybe others.
PS: have called it the mystery shifter as you do not always know which if any gear it is in or is it in nuteral.
kev
Post A Followup
: Re: Rebuilding 544u shift linkage?
