Re: Runs with switch off
Posted by Janicholson on October 06, 2013 at 17:51:15 from (74.60.94.18):
In Reply to: Runs with switch off posted by Robertw on October 06, 2013 at 17:30:29:
Slow the idle to just ticking over without stalling, as David indicates. 450 works if you can get there. If it will not stop dieseling, Put it in high gear, hold the brakes, and let out the clutch as it slows. I consider it very normal, and reducing the idle works well. Newer Farmalls were equipped with a fuel shutoff to prevent the problem. Cars (with carbs had either a fuel solenoid, or an idle stop solenoid to allow throttle closing. Jim
