Re: Runs with switch off
Posted by CNKS on October 06, 2013 at 18:04:39 from (216.144.104.128):
In Reply to: Runs with switch off posted by Robertw on October 06, 2013 at 17:30:29:
You have a hot piece of carbon in one or more of the cylinders. This is a very common problem. You can leave it in gear and let out the clutch part way to turn the wheels slightly to kill the engine, or lower the idle as others mentioned--if bad enough it will still run. I pull out the choke. It won't run without air. Some say that dumps gas in the cylinders and washes the oil off the sleeves -- maybe so. Your choice as to what you use. I don't like it firing like that particularly when it runs backwards so I picked the fastest way to stop it.
