Re: W4 clutch question
Posted by rustred on October 07, 2013 at 11:03:08 from (74.214.152.80):
In Reply to: W4 clutch question posted by 1949H on October 07, 2013 at 06:34:11:
from your description sounds like you have the cover off. you can check the spines to see if there is play in them. might even be the clutch hub rivets are loose. the 4 taper bolts on the input shaft coupler also wear and produce slop. you can even start the tractor and listen to where this noise is coming from. i have not heard these worn parts cause a knocking though.
