Re: Question for Bernard le mecano
Posted by Bernard le mecano on October 07, 2013 at 14:11:03 from (75.158.242.6):
In Reply to: Question for Bernard le mecano posted by StuartR on October 07, 2013 at 04:49:03:
Hi, if you couple the pipe, from the master to the brake piston with a elbow, you cancel the equaliser valve. Your tractor will brake fine, but if the brake on one side have much wear then the other side, the pedal won"t be at the same level. Bernard in Quebec Canada
