Re: Starting a Farmall M , propane powered.
Posted by John A. on October 07, 2013 at 22:07:27 from (64.128.16.238):
In Reply to: Starting a Farmall M , propane powered. posted by Tom Box on October 07, 2013 at 17:44:14:
Tom, My starting point assumes that You have fire, and all other things are correct.
1.,Leave All LP valves OFF
2.,Start turning over the motor like you were starting it!
3.,Crack the Vapor valve just a little, it should start.
If this is the case and the engine starts, You have a bad Diaphram in the Vaporizer!
The reason the engine doesn't start is because it is flooded! If you have questions Holler at me.....512-577-3837. Hope this helps.
Later,
John A.
