Re: F20 Clutch Pedal - rebush / replace mounting stud
Posted by Nebraska Cowman on October 08, 2013 at 05:20:56 from (166.182.3.19):
In Reply to: Re: F20 Clutch Pedal - rebush / replace mounting stud posted by doehmke on October 08, 2013 at 03:57:20:
There is a set screw that holds the stud in. One you
get that out you may be able to pull the stud
through the pedal to remove it.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
