Re: Starting a Farmall M , propane powered.
Posted by Centex Farmall on October 08, 2013 at 06:48:27 from (72.105.164.110):
In Reply to: Starting a Farmall M , propane powered. posted by Tom Box on October 07, 2013 at 17:44:14:
This sounds like an ignition problem. A propane/air mixture ignites at a higher temp than a gasoline/air mixture. If that magneto has gotten a little weak or the points dirty and it's making a weak spark that could be your problem.
Personally, I would lose the magneto and change to a battery ignition regardless. Another thing to try (as Nicholson suggested) is to take the intake pipe off the carb and squirt a little gasoline in and see if it hits.
The fuel filter probably needs to be changed but if you're getting anything through then it should be enough to start; you'll have plenty of pressure with a full tank.
The regulator and vaporizer are combined in one unit. Most M conversions copy what the factory did and to find service information look for a 400 or 450 service manual. The setup is the same.
On the tank, what you can't see is that there is a pipe welded on behind the liquid valve that goes to the bottom of the tank. The vapor valve has a pipe that goes to the top of the tank.
Could you post a photo showing the carb side of the tractor?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
