Re: super C ignition
Posted by John T on October 08, 2013 at 09:21:02 from (67.78.33.134):
In Reply to: super C ignition posted by sparky70 on October 08, 2013 at 08:52:09:
Sorry I have no coil specs or data for any particular coil, however I can give you some basics:
SO OFTEN the cause of a weak spark is the points are burned or pitted or oxide coated or mis gapped which a cleaning or filing etc may help but just replace them if they are badly burned or pitted. True, a condensor can also go bad but Id try the points FIRST
Is the weak spark to the frame or across a plug gap???? If its the plugs perhaps they are the culprit?? Hows the cap and rotor look???
If its a Mag coil, the LV primary may be in the say 0.25 to 2 ohms or so range while the HV secondary will be several thousand ohms
If its a battery powered coil ignition, the LV primary may be in the 1.25 to 2 ohms range for a 6 volt but more like 2.5 to 4 for a 12 volt. Again the HV secondary will be several thousand ohms
A low voltage ohm meter can tell if a coil is definitely BAD like an open circuit, but it cant tell you if its totally good cuz often there are HV breakdowns especially once up to temperature
Run my Ignition Troubleshooting Procedure which may help
John T
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
