Re: Difference between wheel rake and side delivery bar rake
Posted by Roger in Iowa on October 08, 2013 at 09:59:43 from (166.181.81.131):
In Reply to: Re: Difference between wheel rake and side delivery bar rake posted by Zachary Hoyt on October 08, 2013 at 09:38:41:
Never use a "wheel" rake ahead of a forage harvester, unless you have NO rocks. Wheel rake wheels are in contact with the ground and drag rocks into the windrow!
Parallel bar rakes can rake rocks too, but should be adjusted higher off the ground to get the hay but not the rocks.
