Re: building horsepower in a cub
Posted by The tractor vet on October 08, 2013 at 10:54:55 from (75.19.125.100):
In Reply to: Re: building horsepower in a cub posted by old on October 08, 2013 at 08:30:50:
You worry to much . Ya know that you bored it to much is when you stick your hand in #1 and go all the way to #6 with out touching anything , And when you make sleeves up to fill the gap that the sleeves have to have flat sides to fit. You would go bonkers being around watchen us go to the DARK SIDE on engine building . A M M 4 cylinder with 855 Cumming sleeves Allison pistons with Farmall rods with john deere valves , and Oil all Over with big block Chebby pistons a Farmall H with 806 .060 over pistons in it . Never a good thing with me , a progressive size book a set of calipers and a large bottle of C/R and time to think . Can get pretty preverted .
