Re: Starting a Farmall M , propane powered.
Posted by Hugh McKinney on October 08, 2013 at 11:06:27 from (99.195.84.56):
In Reply to: Re: Starting a Farmall M , propane powered. posted by Tom Box on October 08, 2013 at 10:03:40:
Yep, every bit of that, filter, regulator/vaporizer, carb, they are all Ensign units. You can get pretty good kits to rebuild your Ensign reg/vap unit from Everhart in Oklahoma. I have installed the kit in mine but haven't put it on yet, still using an Impco. But keep in mind that if you truly suspect a problem with the fuel system, you can always temporarily, I say, temporarily, bypass the filter, and also borrow an Impco regulator/vaporizer just to see if that does the trick. Not that difficult, even though it will not look very tidy:)
