Re: super C ignition
Posted by sparky70 on October 08, 2013 at 14:14:28 from (38.114.66.153):
In Reply to: Re: super C ignition posted by El Toro on October 08, 2013 at 12:34:56:
I thought of that, just did not take the time to do it. Anyway I found the culprit(s). 1st: the contact switch on the starter was corroded badly. Cleaned that, checked the brushes and she turns over much faster. Obviously a significant voltage drop eliminated. 2nd: this one I do not understand,had gas on a plug when I checked it for spark and gas to the carb, so I figured I was getting gas....wrong!! Pulled the plug on the bottom of the carb and in a second or so it flowed. Open all the lines let the gas run thru, reconnected and she is running. Not sure I have an answer there but thanks for all the inputs.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
