Re: Re: Voltage to magneto
Posted by Bob M on December 04, 2000 at 11:06:14 from (192.232.119.194):
In Reply to: Re: Voltage to magneto posted by Red Dave on December 04, 2000 at 10:23:50:
Red Dave - Your comments are right on. A true magneto is self-powered - the only external wiring is the shutdown grounding wire. Disconnecting the wire while the engine is running will have no effect. Dave - Sounds as if a clever person figured out a way to utilize the original Wico magneto coil as a battery ignition coil. I guess it's theoretically possible, though I've never actually seen it done. And your description describes perfectly how it should work. When you remove the mag cover, is the coil still there inside? Can you see how it's wired? So long as it works, I'd be inclined to leave it as is. Only thing I'd check is the current draw in the low voltage feed wire. If it's more than 2 or 3 amps, consider adding a ballast resistor in the feed wire. This will lessen current draw and reduce the sparking at the breaker points.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
