Posted by D Slater on October 09, 2013 at 05:33:36 from (184.14.160.234):
In Reply to: 300 T/A posted by dkr on October 08, 2013 at 17:12:04:
Without more info its a wild guess. If its a farmall model its not to hard to remove the top cover on the center housing. Look in the t/a clutch compartment for bad pressure plate or release bearing or connected parts. Look in the t/a section for signs of metal loose bearings, broken parts, excess movement of the planet gears on the shafts, etc. Still not found? Check the transmission input shaft out of the t/a to transmission main shaft bearing or input and constant mesh gear. look through the belt pulley gear box opening. If the noise is still there when the main clutch is disengaged. Check pto drive parts. About the only thing that can be done without repair if the t/a clutch doesn't slip is in the t/a clutch section. Get the release bearing or related parts if damaged away from things and then just stay in direct t/a. May make tractor harder to shift.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
