Re: 560 keeps blowing hydraulic line
Posted by mkirsch on October 09, 2013 at 06:14:47 from (64.80.110.74):
In Reply to: 560 keeps blowing hydraulic line posted by Ryan K on October 09, 2013 at 04:45:11:
It is an open center system. The only time the relief valve should be activating is if you are using the hydraulics and you reach the end of the cylinder travel.
If this line is blowing with the tractor just sitting there running, you have a blockage in the valve stack, along with a relief valve problem.
The relief valve should activate to prevent the line from blowing, but also, it should not be activating in the first place.
