Re: M VS 400 DISTRIBUTOR
Posted by Janicholson on October 09, 2013 at 21:10:06 from (74.60.94.18):
In Reply to: Re: M VS 400 DISTRIBUTOR posted by luv2wrench on October 09, 2013 at 19:13:13:
The 400 dist. will work on the m. It will run fine. The 400 may have less advance than the M was designed for (I do not know this as fact) but it will run. A antique distributor machine or a good adjustable timing light and a dwell meter can be used to get it correct.
Much depends on what has been done to either the M in its history, or the 400 distributor in its history.
The timing curve and total; advance are to be found in the repair manuals of each (or in D Slater"s, mkirsch"s, or pete 23"s head) Jim
