Re: 560 keeps blowing hydraulic line
Posted by HydroTek on October 09, 2013 at 22:33:29 from (69.27.61.74):
In Reply to: 560 keeps blowing hydraulic line posted by Ryan K on October 09, 2013 at 04:45:11:
you state in the OP that the main line is blowing, the main feed line is steel on each end with a rubber section in the middle, if you are blowing this line (approx $300) there is a serious problem with the relief valve. The small screen you cleaned is right beside the relief valve, be sure the small piston(approx 1/2" diameter) under the heavy spring is moving freely
