Re: alternator draw
Posted by Raner on October 10, 2013 at 03:41:53 from (173.175.94.231):
In Reply to: alternator draw posted by ken house on October 09, 2013 at 14:14:42:
Easy way to test for a draw...
Disconnect positive battery cable...
Connect a test light, wire lead to cable and the test light point to battery...
If there is no draw the test light will show no light...
If there is a draw the brighter the test light bulb is the bigger the draw...
If you want to check your test light connection connect it as described above and
turn on any kind of electrical component and the test light will turn on...
Note...If you have the test light connected for a long while just touch the cable
to the battery before you continue checking...
If you don't have a test light any light assembly with two wires and a blub will
work...
